S14rida wrote:...i know to many people who have blew the sub because they have had to small an amp.
To clarrify something. Clipping does NOT kill drivers, power does. Example. If you put a 200w amp on that sub and cause it to clip, it'll put out approximately ~400w. As you can see this is FAR lower then even the RMS rating out that driver. No damage AT ALL, except to the amp, will be done.
Question: Are you going to be competing with this setup, because the H2 is mostly for comps, not normal use. It simply does not have the SQ for normal use.
If you're not going to compete, I would recommend that you look at what Adire Audio has to offer. They known for having SQL drivers.
Another question, what mains are you using? The reason I ask this is due to the fact that alot of people focus way too much on bass, and not enough on the rest of the frequency range. This is most likely because bass is so easy to get, whereas the rest of the frequency range requires a little bit of knowledge to get right. Unfortunately alot of people think like this, "It go boom, that good". These are the people whose head I want to rip off . I mean, it's just a total disrespect to me, and even more so to the engineers that designed their products to sound good over the entire frequency range.
anyways, enough of that rant.
What made you decide on the orion amp? I'd recommend that you take a look at hifonics. They have a very low dollor per watt rating.
