SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Mar 11, 2003 5:26 am
The max PSI on the S15 has nothing to do with the actual engine though, all the SR's can take more that 18psi. The turbo will pump out up to 18 psi on a T28. $5500 is rediculous to, for 300 rwhp me since you can get an S13 for $2000 (now seems to be commonplace) and then get larger injectors for 450 and a turbo upgrade for about 2500. That "could" net you 400 hp. Of course it is noted that 400 hp requires alot more parts and tuning but at least the turbo you are running would be capable of well over 300rwhp. Also do remember the S15 doesnt come with 300hp stock, you need to buy a boost controller so knock up that price a bit more(~$450), and you will probably need a proffessional install.
But if you wanted to just buy the S15 injectors ($400) and the T28 turbo ($900 brand new), boost controller ($450) then thats $3300 for your 300rwhp machine. BAM, saved $2200 (not including S15 install), that could go towards ohh maybe say an FMIC, exhaust, etc...
Of course genx, it seems to be "in one ear out the other" to all the noobs.
