S14 (OBDII) vs. S13 (OBDI) Engine/transmission
REDWINTERZ
Car: 1994 Nissan 300ZX (Aztec Red with Black Leather)
Hi,
I'm buying an S14 Kouki (OBDII) shell this weekend, and I'm also hoping to buy a motor/trans (OBDI) from an S13 with 112K on them to put in the kouki. I've done some research and apparently the only difference in the motor is the distributor and the upper intake manifold (Kouki is OBDII and has extra sensors on the manifold). However, I'm not sure if the transmissions are the same as well, or if there is something different. Like I said the motor will be OBDII compliant without too much hassle, but what about the transmission? Thanks for your help guys! :bigthumb:
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
pretty sure the transmissions are the same
DanThaMan
Car: 1993 240sx
s14 transmission bell housing has a hole to accommodate the CPS...other than that, they are identical.
