zmannz »
https://forums.nicoclub.com/zmannz-u23244.html
Wed Sep 28, 2011 3:19 pm
UPDATE:
So, I went and played with the car some at lunch. It was back to cold when I opened the hood, I double checked all the wiring and the hoses. All seems right. I started it up and let it idle about 10 minutes until the temp needle started moving. I revved it up a few times, all the way to redline, and then held the revs at 2500 for a good 30 seconds. After it came back down to idle it dipped low and then held fine. After that I revved it again and couldn't get any bad feedback.
Pulled out of the parking lot and slowly made it out of the service road to the main road, and accelerated hard up to 50mph on that road. After I started cruising at 50, the jerking and hesitation started again and for the first time the CEL popped on while at cruise speed. Every other time it has come on while sitting still in gear when the engine dips to nearly stalling out.
It stalled every time I stopped after that until I got to the auto parts house. Revs drop normally then it bogs down, sometimes even the oil light pops on for a sec. I let it sit there for a few minutes while I bought some things and then walked over to grab lunch. After I came back I checked the codes and it came up 21 only again. I started it up without clearing the codes and it idled like crap, as if the Idle control valve was dirty or just not working. I reset the codes and drove it to another parts store where it was parked for almost an hour. After that, I started it up and it idled fine. I dorve it easily back to work, and it didn't start jumping and hesitating again until I was almost back. So, I drove it around the lot some, did some sliding around, hard braking, and hard accel, and it would only jump and hesitate under light load, ran seemingly fine with the gas floored. After that I parked it and it idled nearly fine, but would almost drop out then idle again if I popped the gas a little. Couldn't get another light to come on. I am about to drive home from work so we'll see how it goes again. I bought a nicer meter today that measures ignition dwell and a mass of other things, plus it is way more accurate for dc than the fluke and ideal testers I have from being an electrician. I am going to ohm out and test all the ignition stuff again tonight and clean the iacv. Think I should order a set of injectors or fuel pump to try? I tried unplugging each plug wire while it was idling crappy to see if one didn't make any difference, but they all seemed to make it run worse which tells me all 4 cyls are at least getting a good spark. I have another s14 ecu somewhere in storage, so I am going to dig that up asap and see if its for an AT car. If so I will try that too for s*** and giggles. Any ideas are appreciated. I am almost ready to part my s13 coupe to get a swap for this. I never have issues with swaps like this!
