S14 nismo differential flange issue
ORUG@
Car: Zenki S14 Silvia
Greetings
all info will help !!!!!
alright i bought a differential from nismo to install into my S14, everything fit except the flanges one being too long....
how could i solve this problem.......has anybody run into this problem before
PapaSmurf2k3
Site Admin
Which flange are you talking about?
ORUG@
Nismo flange
bought nismo gt lsd came with differential and flanges "flanges to replace oem ones"
something i didn't know there is more than one size that come with this kit.
PapaSmurf2k3
Site Admin
Ok help us out here.
Flange to the driveshaft, flange to the halfshafts/axles, flange for the diff cover????
ORUG@
flange to the differential to the axels
i posted a link to show the parts i'm having issues with, time is different
https://www.ebay.com/i/174085503947?chn ... gIqz_D_BwE
PapaSmurf2k3
Site Admin
So one axle fits and the other is too long? Are the 2 the same length, or if the one that works is shorter, can you swap it to the other side and verify it works there, and then just buy/replace that 1 axle?
ORUG@
alright a little bit more into. spline count is correct.
neither one of them work.
one being short retaining clip doesn't lock to diff
one being too long goes pass locking clip and hit the shorter flange inside the differential
they are assigned to be installed in a specific way, can be swapped
