s14 Negative Camber
MIKEL240
Has anyone here tried the negative camber kit for the s14 they have on EBAY? They say it's for the 1995-1999 240sx's. It corrects camber from -1 to +1 degrees. Has anyone ever tried this camber kit? If yes, does it work at correcting the negative camber? If no, does anyone here have any ideas about how to correct the negative camber on my 95 s14? Please any ideas would be helpful!
alan-n
Car: 95 240sx
Yes it works fine for daily driving, but is not solid for hard cornering. If you are driving it hard then get camber plates / adjustable arms.
Ligouri Rd
Car: '96 Nissan 240SX
:WerdBuuut, how low did you drip yer car, also front or rear?Cause if its around 1.3" in the rear you should have enough adjustment at the inner upper arm mount to bring it back to 1 degree (which is fine). I put H&Rs on my car with adjutable upper arms and I still have them at stock length. The front on the other hand, I had 1 degree on the drivers side but 2 degrees on the passenger side (I have camber plates=loud and xpensive, but i needed them for autox). Get the car aligned (you may have already done this). It has probably been said many times before but anyhow: Camber does not wear out tires, excessive toe does.
