s14 motor in s13
erollinc
i definatly just scored a s14 motor with 27K on it and i need to know if i should just wap out the intake mani to make it work or jsut get the ecu and all that stuff and the wiring and jsut swap out everything....i tried a quick search but only came across s13 into s14
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
alright ugly, i covered this ****er like fifty times, but since i'm only part d!ck, i'm gonna help you, but quickly only....
Use everything S13 you can, use the harness, ecu, exhaust manifold, ac compressor and bracket, the cams especially, **** what else, i think thats it
Use the S14 block and even use the intake manifold, just swap your coolant temp sensor and the thermal transmittor sitting right next to it
its really easy, and making it S14 makes it much more difficult, the only gain you get is a little nicer tune and a slightly larger MAF
slyde
Car: 1990 240sx
"alright ugly" lmao ahhhhhhhh i needed a good laugh.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
yea i just put an s13 motor in my s14, just swap over all the manifolds and emissions stuffs, i used the s13 block and head only really..
okMarko
erollinc
so swap both intake and exhasut manifolds.... and im good right?
im probly jsut going to toss the ac
nothing different about using the s14 transmission on there right?
coupebuddy
Car: 89 coupe 96 motor 93 harness 91 auto ecu cai,msd,plug wires,12v charged ignition,hyper grounded,stru
you can use the s14 intake.just wire in the s14 iac and run the fpr from the iac vac line.Mine is set up the same way and I have no problem with my engine.it run great and idles great
