S14 Manual Conversion Parts for S13
omgdudewtf
Car: 1993 240sx SE
I ordered a bunch of manual conversion parts a long time ago from ebay, listed to work on S13's and S14's. I find that to be incorrect (my fault for not researching I guess)
The **** I got was all S14 parts...or thats my best guess. The clutch line was completely different. The clutch pedal spacers were on the assembly when the S13 already had them on the car, so I just cut the spot welds off the pedal and got it to fit. But I just noticed the bottom clutch position sensor is against the firewall with no room for a connector.
Cliffs/Questions:
I got S14 conversion parts for my S13.
--- Can the clutch pedal assembly be made to work? Will the master/slave cylinders and mount and everything be the same?
s14fiend
Car: 1996 Nissan 240sx
Well I have a 1996 240sx automatic which I am trying to convert to manual using parts from a 1993 manual. If you want you give me your donor car and I will give you my donor car. Or we could also interchange the hardlines that come out of the clutch master cylinder. LMK.-Adam
