s14 mafs on an s13 ka-t? will it work or am i screwed?
zerepdivad
Car: '90 240sx . '02 Lexus IS300
ok well i bought a dohc s14 mafs on accident on here because i didn't word my ad right so i received an s14 i believe it to be since it's plastic as opposed to metal. So i'm basically wondering if il'll be able to run it any way or if i'm screwed and should start looking for an s13 one. let me know if there's a write up on it as well i searched but didn't find anything.thanks
RB260sx
Car: s14.5 260sx
i think its better for you to use a z32-t mafs instead and resell the s14mafs on ebay.
TheOne
Car: 93 240sx FB
if you have a stock ecu, you have to use the MAFS from the sohc, if you have an safc2 or equivalent(tuned ecu for z32, & others), then you can use a z32 mafs.
zerepdivad
well this is a dohc-t and it's from an s13 but the mafs i accidentally bought was from an s14.... so would i be able to run it since i'll be running a safc? let me know any help is appreciated.thanks
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
it will work for you! I think I sent ya the plug as well! If u r running a dohc this maf will work for you!
S13FX
Car: '69 l20b Dimeski :)
Simple answer,
If its a DOHC s14 maf it will work on your DOHC S-13. Now if you were trying to put in a SOHC maf on a DOHC you would need the SAFC to correct for the voltages.
zerepdivad
1995240sxSE wrote:it will work for you! I think I sent ya the plug as well! If u r running a dohc this maf will work for you!
thanks that's all i needed to know. it's just that the plug is different so i didn't know if there'd be any issues.
TheOne
Car: 93 240sx FB
if you used the S14 DOHC wiring harness + S14 ecu, you can use the S14 MAFS, if you used the S13 DOHC wiring harness + ecu, you have to use a S13 DOHC MAFS as those aren't the same, at least as far as i know.(physically those aren't the same, as far as the ecu bein able to read the newer, doubt so.)
eazye2000
Car: S13 KA-DET
An S14 MAF on an S13 wont work.... Even if they are both for the DOHC. So don't let the seller try to let you think it will. S13 and S14 DOHC MAF's are different in design, as well as programming in the ECU.
You will have to change the in/out setting on the SAFC to work.
I believe stock in/out on the S13 DOHC is 5/5 . You will have to put it as 6 in / 5 out for the S14 DOHC MAF to work on the S13 DOHC engine.
This is not guaranteed, but that's what I had to do on mine to make it work. The S14 MAF is a little bigger, and let me run a bit more boost without the MAF going crazy on me. So that's a plus.
Let me know if this helps! If not, put the In/Out settings as 5 in / 6 out.
1995240sxSE
the ecu doesnt decifer the maf, it will work! Plus u have safc II if it dont. I am not trying to screw u round nor was I when I sold it. I am running a s13 ecu in my car right now and before I upgraded to q45 maf it worked!!! If the harness is diferent, just wire it in I sent you the plugs as well! I am not tryin to sound defensive but it feels like people are thinking I screwed u over!
zerepdivad
no i know you didn't screw me over i should have made it clear that i wanted one for an s13 which obviously i didn't do. don't worry about it i just want to know if it will work i'm not holding any grudges if it doesn't since i have an safc anyways.thanks a lot for all the responses. The motors going in within the next few days so i'll update you guys.
