S14 Kouki VIS CF Hood Won't Fit
serpentarius
Hi guys, I just bought and installed a VIS CF Hood. I've heard good things about VIS and the quality is indeed good; however the hood won't close. The metal hook is able to keep the hood in place just that when I press it won't "click" and lock into place like before (reverse of releasing the hood latch, in case I am still unclear). Any ideas on how to adjust for this?
ThuG LyFe
Car: 95 S14
pics? so it "fits" but it just doesn't click when u push down and you have to just let it fall by itself from like 2 feet up?
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Try adjusting the latch on the rad support it prolly needs to be closer toward the hood....and/or try adjusting the two rubber stops on either side of the rad support that support the front of the hood they might need to be screwed in a little.
krayzie94
Car: 1989 240sx
ThuG LyFe wrote:pics? so it "fits" but it just doesn't click when u push down and you have to just let it fall by itself from like 2 feet up?
LOL
livinglegend2100
looooool thats how i cracked the resin around the latch on my VIS
mixeds14
Car: 240
Salem240 wrote:Try adjusting the latch on the rad support it prolly needs to be closer toward the hood....and/or try adjusting the two rubber stops on either side of the rad support that support the front of the hood they might need to be screwed in a little.
^ i agree, but if it lines up with the fenders n lights then just mess with the latch, and dont worry about the rubber stops....
AZ89two4Tsx
Screw the latch. Get hood pins. Much safer.
PancerzSX
Car: 1995 240sx SE SOLD
1992 240sx SE on Stance SOLD
x2
AZ89two4Tsx wrote:Screw the latch. Get hood pins. Much safer.
serpentarius
Yes when I press it down it lines up with fenders and lights, just won't click into place. And I don't really get which latch you're talking about?
C3Sierra_S2000
Car: 1997 240SX SE LS swapped
The hood latch is what is attached to the radiator support. It is what the metal ring on the hood latches into. It is bolted to the radiator support but the holes are slotted so that it allows for adjustment up and down. Loosend the bolts and move the latch upward toward the hood and re-tighten. This should now allow the hood to latch. If the hood is sitting above the fenders in the closed position then the latch needs to be moved down and the rubber bumpers that are on either end of the radiator support need to be screwed in more which will lower them. The rubber pieces are really what line the hood up with the fenders.
tctomasc
Car: 95 240sx
plz buy hood pins before you kill yourself and other motorists.
serpentarius
I removed the rubber pieces it still won't close. It doesn't look like anything in the compartment is in the way. Rather it feels like I simply cannot press down on the latch. When I use a screw driver and apply pressure the latch could rotate, just won't lock into place. Any more ideas?And yes I know about hood pins. But no use installing them right now when the latch won't even close, right?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
What they are asking you to do and I agree, is to loosen the bolts on the hood latch (the latch that accepts the hook (striker) on the hood) and adjust it up, or towards the sky. Then tighten up the bolts and see if it latches.
Did you remove a factory metal hood, or are you replacing after body work?
ZOMG.SR20
Car: 1990 s13
theres a screw driver/ ratchet in the way check for one ive been there and done that
