s14 kouki front
thinhthan
Car: 95 240sx se
so im doing the kouki front end and im taking parts from a 98 240sx. i was looking at the headlight bracket and i was wondering if i have to drill out the tack welds for the headlight bracket. it looks like the bottom of the bracket is bolted but the top part is welded. or does it just comes off? its not my car im taking the bracket off so i cant mess with it
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Do you mean the radiator core? It is welded but you can drill the spot welds and take it off.
motoman399
Car: 98' wrecked (RHD coming soon) 240
well the kouki and zenki have slightly different headlights. so in order to make it like "factory" you would have to drill out the two spot welds on the headlight brackets. but there are few differences between the zenki and kouki headlight brackets. i think the top bolt lines up, and the bottom bolt falls where the hole is for the alignment peg. so to make the kouki lights work with the zenki brackets you would have to either drill a hole in the bracket or cut the alignment tab on the light housing. and use a washer with a bolt and a nut on the bottom bolt hole.
