Holvinator »
https://forums.nicoclub.com/holvinator-u138020.html
Thu Feb 11, 2010 12:09 am
found out what was the problem and it was the (neutral safety switch) which is located "at least on a S14 with Auto transmission" right behing where the shifter is at. Its a little cilindrical plastic tube with a gold pin "believe that was the color" that has a hook where gets hooked up to the Auto shifter.
Well. when I got the swap done (auto to manual sr20) that neutral safety switch was pointing towards the shifter so Im guessing while shifting to 3rd or something I must hit it and caused that pin to get out of place and not letting me to take out keys off ignition.
All you gotta do is hold that clear cylindrical plastic tube with 1 hand, and pull the gold pin that has a little hook and its about 3" long with the other hand towards you. Problem fixed, Now you will be able to take keys off ignition.
To avoid this happen again, put that neutral safety switch right behind the cigarette door "that lil door next to the car lighter". If it does happen again, now all you gotta do is take out that cigarette door and pull that pin towards you instead of removing all that crap on the middle console to get to it.
P.S: sorry for my grammar, english is my 2nd language lol working on it tho : )
