s14 ka24de Needs adjustments and advice
hakosuka86
Car: Toyotas Nissans
the s14 is a 1995 I adjusted the timing so its not running as bad..Idle its a 800RPM BUTit shakes a bit and its leaking a little gas goes down and drips down the header, its a mixture of fuel.plus there's white smoke coming out of the exhaust if i give it gas more smoke comes out.
could it be a head gasket ready to blow?? or excess fuel and fuel on the exhaust which fuel needs to be adjusted????
Modified by hakosuka86 at 8:35 PM 6/3/2008
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
If you are not a native English speaker, please don't take my criticisms personally...
hakosuka86 wrote:I adjusted the timing so its not running as bad..Idle its a 800RPM
Idle should be 650-750 RPM.
hakosuka86 wrote:its leaking a little gas goes down and drips down the header, its a mixture of fuel.
You need to elaborate... What is leaking from where? Also this sentence is horrible English.
hakosuka86 wrote:could it be a head gasket ready to blow?? or excess fuel and fuel on the exhaust which fuel needs to be adjusted????
White smoke is USUALLY burning coolant which would indicate a blown head gasket. White smoke can also, under certain circumstances, be burning oil. Again a horrible English sentence.
