D1SR240 »
https://forums.nicoclub.com/d1sr240-u9505.html
Sat Feb 14, 2004 12:26 pm
I have a 91 240sx, and i'm looking for a new KA. Well i found aone for 400 bux, with 46,000 miles. Only proboblem is that it's from an auto 96 240sx. I know that since mine is a 5spd i'll need to swap the pilot bushing. But since this is a s14 engine then will it go in just as easy, or will i have to do any other things. The engine doesn't have a distributor so can i use the one from my 91 KA. I also heard that the 91's have better cams. Can i swap in the cams from mine, or do i have to use the s14 ones? Is there anything else i have to worry about since its from the s14 or will everything go in good? Also will i need the 96's ecu? or can i use mine?
Thnx in advance
