1sikS13 »
https://forums.nicoclub.com/1siks13-u47232.html
Thu Nov 13, 2008 2:54 pm
im planning on picking up an s14 shell with the ecu and wiring harness for a good deal. My question is im running a 98 motor in my s13 with the obvious s13 distributor that does not have the internal coil. My question is can i take that extra 3 wire plug that would go into the s14 coil, cut it, extend the wires and run a msd blaster coil, with an s13 coil. Just an an ignition upgrade, cause i already have it. The only reason i would be upgrading it is cause i am goin ka-t over the winter and i wasnt planning on doing this with an obd2 system.
EDIT forget the tuning question
Modified by 1sikS13 at 5:05 PM 11/13/2008
Modified by 1sikS13 at 5:06 PM 11/13/2008
Modified by 1sikS13 at 4:55 PM 11/20/2008
