s14 KA running rich, hard to start and shakes bad.
soultron
Car: 1995 (early) 240sx
Hi guys.I have that s14 we got out a ditch and I've been fighting with it.Ever since we replaced the motor it's been VERY much more powerful, but idles like Micheal J Fox off the meds, takes a long while to start and smells pig rich from the exhaust. I've search a few forums, but I can't seem to find any good ideas.
It's timed to stock spec, has a few new sensors ( O2,CTS,CPS,)New plugs but no other ignition partsNo current codesIt was a late 95 (obdII) motor, but the car is OBDI, so I swapped the intakes (new gaskets).
Vacuum leak? EGR or IACV? I'm not coming up with much.Any help would be much appreciated.
Modified by soultron at 12:16 PM 10/1/2009
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
only a few things i can think of for you to look into..
#1.) fpr...fuel pressure regulator.
#2.) fuel injectors..
#3) Idle adjustment/airfilter
#4) timing.
#5) coil/plug wires/cap/rotor
thats about all that would cause that...poke around those area's then get back to us with what ya find..
soultron
I haven't gotten back to the car yet, but I think this weekend I'm doing the subframe bushings, so I should have time to run a few tests then.
