need some help guys, also posted in online mechanic
put my ka24de back 2gether and fired her up and oil light is on. block is fresh out of machine shop, honed, new piston rings, new main and rod bearings.ka is firing up perfect no bearing noise. middle chain tensioner is makin noise since not enuf oil pressure to head.1-2lbs tops of oil pressure at sender even while reving.does no oil pressure at oil sender = bad oil pump? can incorrect bearing clearances lead to low oil pressure? i do not hear any noise comin from bottom end (bearings not gettin any oil should be audible) , only sound is from lower chain tensioner not gettin ne oil pressure.Do you have to seal oil filter assembly with any type of liquid gasket when reassembling onto the block? I had to mount oil filter assembly after gettin block back from machine shop and i did not seal it. Is there ne way to tell if bearing clearances are off other than breaking down the bottom end?
