S14 jdm silvia K's brake swap
Dauer
Car: snowboarding, mx, motors
Anyone have any knowledge of doing an S13 to S14 jdm caliper and rotor swap, I know the 1996-1999 jdm S14 Silvia K's had iron 4 pot calipers but am not sure about the width and diameter of the rotor.
Nismo_Freak
Car: 89 Nissan 240SX
280mm x 26mm
4-Pot Nissan Caliper
Dauer
right on, that means I can use the rotor from a 1990 N/A z32.
Dauer
Also would I have any trouble sourcing brake pads for the calipers?
Nismo_Freak
Nope, use Z32 n/a pads.
Dauer
thanks, Nismo_Freak
Nismo_Freak
np
CaptainHenreh
Nismo_Freak wrote:280mm x 26mm
Nismo_Freak wrote:Z32 TT - 280mm x 30mm - 4-Piston NissanZ32 Na - 280mm x 26mm - 4-Piston NissanQ45 (pre-97) - 280mm x 28mm - 2-Piston NissanQ45 (97-01) - 296mm x 32mm - 2-Piston Nissan (?)S15 - 280mm x 30mm - 4-Piston NissanS14 - 280mm x 30mm - 4-Piston Nissan
(from Here.)
Not to nit-pick, but which is it? I suppose I could go get a ruler and measure mine, but I'd really rather not. If it's 26mm, wouldn't it have the aluminum caliper? (I'm quite certain my calipers are aluminum)
I think I'm going to buy new rotors for my S14 K's brakes, but I'd like a difinitive answer. (again, I'm too lazy to measure with a ruler, and my micrometer is in inches.)
Dauer
Yes, CaptainHenreh I see where the discrepancy lies, so which is it 26mm 0r 30mm? The S14 caliper itself looks to be iron, I base this on it's lack of cooling fins and the fact that the S14 K's were produced in the late 1990's when it seemed that most if not all of Nissan 4-pot calipers were iron. Again, correct me if I'm wrong because I'm simply drawing inferences.
CaptainHenreh
Dauer wrote: The S14 caliper itself looks to be iron, I base this on it's lack of cooling fins and the fact that the S14 K's were produced in the late 1990's when it seemed that most if not all of Nissan 4-pot calipers were iron.
They're iron. Magnets don't stick to Aluminum.
I'll measure when I get home. I suppose it's possible there was a model year change, but I doubt it. I imagine they are 30mm.
Dauer
right on, let me know
CaptainHenreh
Definitely iron.
Definitely 30mm in width.
Dauer
good to know
s86d
Car: autocross, backroad racing, and working on 240's
and they definately make rim selection a biach (Having that trouble to this day) so far Z32 rims work on both 26mm and 30mm. S14 SE rims work on only 26mm Z32 brakes and !!we need a sticky on what works, (fitament wise) for Z32 brakes because I just wasted $1000 on rims that dont fit that I thought would :mad:
CaptainHenreh
s86d wrote:and they definately make rim selection a biach (Having that trouble to this day) so far Z32 rims work on both 26mm and 30mm. S14 SE rims work on only 26mm Z32 brakes and !!we need a sticky on what works, (fitament wise) for Z32 brakes because I just wasted $1000 on rims that dont fit that I thought would :mad:
Just to clarify:
S14SE wheels will not clear 30MM Z-Brakes? You can confirm this?
How well does a Z32 wheel fit on the car? Does it stick out the fender/rub suspension bits?
s86d
the S14 SE rims only fit on the 26mm brakes you would need offset spacers for them to clear on 30mm IIRC <7mm which is kinda bad. still doable some people use a 10mm spacer its just a growing risk thats all.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
I think after 1993 or so they made the 30mm calipers in iron because the aluminium ones warped
so stock S14 SE wheels clear only 26mm? crap :(
CaptainHenreh
The day before yesterday I saw a 95 S14 with SE wheels and 30mm Z brakes.
It was close, but it cleared.
Dauer
any indication of the use of spacers?
