SeVa-S13 wrote:Those are the little jackpoints for those horrid scissor jacks but he asked about where to place jackstands, which is on the framerails, no?
On my S13 I use the frame rails (if you can use that term on a unibody car) and put the stands just behind the little oval holes in the rails.
If you want to be extra super carefull put a small piece of wood between the jackstand and the vehicle and carefully watch to make sure the rail doesn't deform when you let the weight of the car rest fully on the stands.
Just make sure the stands are on an even surface and if you use a small piece of wood, make sure it seats properly on the stand. You don't want to have any kind of wobble...would suck to be under the car if it slipped off of a stand. I also try to leave my jack under the car too, unless it's in the way of whatever I'm trying to do.
