BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Tue May 06, 2003 1:42 pm
miteymax, STFU you a$$hole. You have no reason to flame him, an S14SR into an S13 is not a common question, so get off your throne and back the fuc/< off. Jesus Christ, if all people did was search google all day long, there would be no need for forums, which means no forums for you to flame people on. We don't need d!ckheads around here like you.
Now that is taken care of... :rolleyesFor intercoolers, if you are going front mount, you will need the intercooler for your MOTOR not chassis, so an S14 FMIC for you. If you are going side mount, I believe the mounting position is the close, if not the same, you will have to widen the holes a little bit though. The hotpipe on S14's doesn't do into the same place as on S13's, so you may need a custom hotpipe, which in this case will probably be an S13 hotpipe.
For wiring, it's going to be close to S13 -> S13 wiring, but functional A/C will not be easy. phase2motortrend.com has done an S14 into an S13 with functional A/C I believe, so you may want to ask them.
Fan shrouding.. hmm.. good question, I believe it does, may need to trim a little off the shroud, if not, recommend you get an electric fan anyways. Get some 100 dollar thing off the internet, and you will be good. Or get a good one, up to you.
Good luck with your swap.
