s14 iNTERIOR PROBLEMS
hakosuka86
Car: Toyotas Nissans
Hello I have an 1995 se 240sx My sunroof works it turns when i press the button but it doesn't move up or down or back n forth how can i fix it???is the track blocked??
My passanger window works fine so do the locks BUTAnd my driver window Doesn't Move at all when the button is pressed. Thats it thank you very much!!!!!!!!!!!!!!!!!!!!!!!!
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Your driver's side window is likely the window motor amplifier, which is a little white box held on my two bolts behind the door panel. Remove that and you'll see it plain as day. They commonly go out on our older cars.
As for the sunroof, it sounds like your saying the the motor makes noise but doesn't do anything? Get in there and check the linkage and make sure it's connected.
hakosuka86
I will check for the door,as for my sunroof ill try to check the rails n the connection since last time i was working on it and pressed the button it didnt even make moving noise.
thank u very much im glad theres nico members like u that always help out!!!
