S14 Intake Mani on S13 + emissions removal
benz88
Car: 91 240sx
Alright i know its been brought up, And ive searched. But all the pics are DEAD. I want to strip down my S14 intake and put it back on(S14 motor in my S13, Currently running the S13 intake). Now I need pics of What i can remove from the manifold as far as emissons go. If someone can please post pics or link me to pics it would be great.
benz88
Car: 91 240sx
anyone? even the pics in the tech session are down.
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
i was looking for a writeup as well and all pics from all forums are dead link now...
bushido
it's simple.
get the manifold off and you'll know what to work with.
if you have the s13 manifold still, i suggest you use the s14 upper and s13 lower.
this way you eliminate the s13 butterfly valves.
plug the egr with a block off plate from ebay. (octopus style)
the little vacuum hoses that come off the runners should be pulled, holes tapped and threaded plugs installed to prevent boost leaks.
you can fux with the coolant hoses at the throttle body n such but its not necessary..cold start s***
