Cool i'll give that a shot, thanksfiznowler wrote:I have a 94 civic hatch along with an s14. My hatch did this exact same thing. Mine was the dimmer switch on that car. I don't know if honda and nissan would be exactly the same but prob similar. I tested it by jumpering 2 of the wires behind the switch with my lights turned on. There were 3 wires on my honda a red, black and red/black stripe. You should be able 2 jumper 2 of the wires and your lights work if the switch is the problem. If they work after that you need to either replace your switch or bypass it by hard-wiring the 2 wires you jumpered. if you hard-wire your lights will be on the brightest setting always and can't be adjusted. Like i said this is what i did on my civic less than a week ago to fix it. May be worth a shot on the 240 as well.
I tried jumping the 2 wires in the dimmer switch, I had a red w/ blue stripe, and red w/ orange stripe, and black, tried all possible combos, and no luck with the lights.fiznowler wrote:I have a 94 civic hatch along with an s14. My hatch did this exact same thing. Mine was the dimmer switch on that car. I don't know if honda and nissan would be exactly the same but prob similar. I tested it by jumpering 2 of the wires behind the switch with my lights turned on. There were 3 wires on my honda a red, black and red/black stripe. You should be able 2 jumper 2 of the wires and your lights work if the switch is the problem. If they work after that you need to either replace your switch or bypass it by hard-wiring the 2 wires you jumpered. if you hard-wire your lights will be on the brightest setting always and can't be adjusted. Like i said this is what i did on my civic less than a week ago to fix it. May be worth a shot on the 240 as well.
oh yeah, i saw this DIY, might give it another go, I couldn't find the same TCU box as in the picture, but I think it might be above the fuse box. *very hard to work in that space*fiznowler wrote:Read that link. Looks like might be your problem and that would explain why you weren't able to ground out the wire and make it work. The article doesn't specify if it is for s13 or s14 or both but it is worth a shot!
zerothread/158162
Alright i'll try it out when I get back from work, thanks dude.motoman399 wrote:no that is not a box. it is just two weird plugs. one comes into the cab from the front harness and one goes to the back of the car. do as i said and take the switch apart. i had the same problem as you and it blew a fuse also. it was the tail light fuse.
1) check fuse2) take apart dimmer switch check to see if circuit bored is burnt on one spot3) start checking wires with ohm meter and test light
should i take a post a picture of it on full ? haha before and after?Hoffman5982 wrote:you should probably get some gas
Yeah it works fine. Dims the lights and everythingmotoman399 wrote:does your dimmer switch work? i just remembered that mine quit working and that is why i took it apart in the first place.
I'm having the same issue with my S14. I've checked the tail lamp fuse and it too was popped so I replaced it with another 10A and that popped too. I put a 30A in there and it didn't pop, but then changed it back to 10A. This one did not pop but still no lights on the dash or parking lights.3ps14 wrote:turned out the to be the tail lamp fuse popped, didn't think of checking every single one, thanks motoman399
fixed it ... and then some...
