invain »
https://forums.nicoclub.com/invain-u96301.html
Sun Nov 09, 2008 5:45 pm
Been having some problems with the ka-t again and I've got it narrowed down to ignition. The problem has been very intermittent, which doesn't help matters because everytime I try to check things out the car runs fine.
What I'm getting is bad stuttering/loss of power through pretty much all rpm's. When I take off from a stop the car almost falls on its face and I can tell I'm losing a ton of power, just drives like absoulute **** and bucks half the time. Sometimes one cylinder will stop firing completely, and although the sputtering stops of course it drives like ****. The strange thing is, it does this randomly. I drove the car 110 miles from home to college and it was perfect the whole trip. 3 days later I'll drive 10 minutes to get groceries and it's drives like ***. A week later I hope in and it's driving normally again.
I pulled into a rest stop one day when the car was acting up and found cylinder number 2 was not firing. I was pretty sure this was electrical since the problem appears randomly so I started with the cheapest fix and got some new spark plugs. Just put the new plugs in today and it does drive a teeny bit better, but half way back to my apartment it starts acting up again and is sputtering/losing power like mad. Half an hour later I leave for a football game and the car drives like a dream there and back.
Obviously it wasn't bad plugs, so now I'm thinking ignition coil? I haven't taken the distributor cap off yet to check that out but the original owner of the car had recently replaced the distributor and wires so I don't think it's either of those two.
I tried checking in the FSM but I still don't know where the ignition coil is. Any of you guys have any diagrams/pictures? If I replace the coil, should I just get an oem one or would an aftermarket one make any difference?
If it helps any I'm running about 8 psi and the car has cams as well.
