S14 Hubs?
TougeChallenger
Car: 91 240SX
Does the S14 5 lug hubs fit on the front and rear on the S13 or is it just the rear? I just heard that from someone, i pretty sure its just the rear and then u can run attains or peak performance on the front.Just wanted to double check before i go and spend some money. thanks
SmithSR
Car: 240sx
S14 rears are direct, so are N/A Z32 rears, but the S14 front spindle is larger diameter than S13.
Idea for fronts: You could always swap an S13 bearing into an S14 hub to fit onto your S13.
Good luck!
cdlong
Car: '95 240sx
or you could swap an s14 spindle, with that you need an s14 ball joint. you could use the entire arm, but it's longer. or you could press s14 ball joints into an s13 arm. you'll also need to drill out the shock mounts and use s14 shock bolts or buy some spacers for the s13 bolts.
there are plenty of options, do some research and shop around for parts and decide for yourself.
TougeChallenger
Car: 91 240SX
thanks for the info,i think i will press the S13 bearings into the S14 hubs for the front and run some Z32 for the rear.
