nyc240sx wrote:Also one more thing i started up my car and my speedometer is not working does anybody know if the same sensor from the automatic transmission goes into the manual transmission i looked on the manual transmission and i didnt see the hole where it goes into..Would any one know this? thanks
No the auto transmission speed sensor will not even go into the hole on the 5 speed transmission - its too thick - and the mounting hole is on the wrong side
If you have a s14 chassis you need a s14 speed sensor (almost impossable to find / very expensive - and most will try to sell you the auto speed sensor) - They look different and differnt size - its all on the DVD
If you have s13 chassis - you need a s13 speed sensor (easy to find / cheap)
not sure what you have in the hole right now? but if there is no sensor in the hole transmission fluid will pour out of it!
The speed sensor is located at the back of the transmission on the passenger side - its the last sensor on the transmission - pretty much right below the shifter plate.
the s13 and s14 sensors are different as well and you can not use one for the other as far as the s13 to s14 chassis and vice versa
