s14 help needed
95 S14
So here is my problem. I am getting fuel to the engine, but no spark. No current to the ignitor or the coilpacks. I traced the wires from the engine to passenger kick panel and it appears the wires from the ignitor run into the ecu. They are red/white, red/green, red/yellow, and red/blue. Does this sound right? Does anyone know how I get the ignitor and coilpacks to get power so I can get my car started? When I turn the key to on there is a red l.e.d in the ecu that lights up. Is that right? Need help desperately.
Thanks
P.S. It is a 95 240sx se with a 95 sr20det engine being swapped
s13sr20chris
you need to go over the swap instructions for your engine. there should be a dedicated power wire for the ignitor chip. im not sure which one it is though. is the motor from a 95 s14 or s13?
95 S14
its an s14 sr20det into a 95 240sx se
s13sr20chris
do you have the fsm from zerozon.com?
