S14 headlights
Yuhboyq
Car: 89 240sx
my s14 headlights are hazy but i think its on the inside of the housing. basicley how do u seperate the houseing from the cover? and any good cleaning tips?
BoBa524
Car: 1995 Nissan 240SX SE
its not on the inside, its on the outisde. search there was a huge write up that i followed. zerothread?id=174789
i did the search for u
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
mostly like if you own 95-96 it's the outside... unless of course you have a leak and you can visually see water vapor. then it would need to be dried out and sealed.
Yuhboyq
Car: 89 240sx
thanks dude that helps a lot. appreciate it.
blinkshome
Car: 95 240 ka24det
try using some rubbing compound on a rag. works great. rub it out like you would your paint.
