Damn, bro, never let your girl drive your car, especially if you're not in it!:whipped
J/k, but here's an idea. try taking the headlight housing out, and remove the bulb. with all that crap out, let your housings sit in the sun or something so it dries. a fan would probably work too. get some of that blue magic metal polish and go to work on the outside of your housings. Not sure if that will work, but it's what I'd do.
a more extreme method would be to heat your housings up enough to pry apart. clean the insides and maybe even try buffing it with dishwashing liquid, I use that on my helmet to keep from fogging up. then get some silicon and seal the housings together, and cook them to get it to heat up and seal. this is a really sketchy explaination, but if you want to do it that way, I can ask my civic buddies exactly how to do it and post that.
the other option is euro headlights or s15 front end!
girls only drive after about 5-10 autox's and can drift as good/better than you. then you marry her and never let her go.
