S14 Header/Cat question
KC224
Since the 1st cat after the exhaust manifold is getting removed to install the header.
I was wondering if I put a real cat where the 2nd cat is, (since it's apparently just a dummy cat) would it be legal?
Adam240sx
Car: 1995 240sx
I didn't know s14's had two cats?
KC224
Yea that's what I'm saying, do they consider that a cat or a resonator for legal purposes?
Sorry thought I put this in my first post... I'm installing a DC sports header. It removes the real cat to go down to the dummy cat. So if I place a highflow cat in place of the dummy one would it still be legal with the cat law?
Nesquick
Car: Rb26 Kouki Silvia
depending on where you live. if you have smog tests or stuff like that, id keep the exhaust as close to stock as possible. cops are another issue. if they are really anal where your from, id keep it as close to stock as possible
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
What year is your car? On my 95 the first one is the dummy cat and the second one is real, so the header only replaces the dummy. If its an OBDII car or a Cali car though idk, they might both be real.
KC224
95, but it has the obd2 hook up under the dash on the passenger side.
So with your setup is it legal since you still have a cat in the oem spot, or do they count the dummy cat as an actual cat? It's an AZ car so emissions doesn't matter. I'm just wndeing about the removal of the cat law.
Dittoz7
Car: 1997 2f0WtY SE!
Well depends on what your definition of legal is.
If a cop pulls you over, I doubt he'll ticket or tow for not having a cat, cause you do. Legal
If you try and smog it with 5 cats on it and still fail. Not legal
dgms240
Car: '90 s13 hatch ka24det
on a 95, the first one (bolted to exhaust man.) is the cat. the second is a resonator. And depending on where you live, as long as you have a cat installed you should be fine. On my old s14, I ran a hotshot headers with a high flow cat bolted on at the flange at the end of the header.
KC224
Yea that's wha I planned to do. So I guess its half legal haha should be fine in AZ like you said though. Thanks guys
