S14 Greddy header?
Timos240
Car: '95 240sx not quite stock,
Did Greddy ever make a header for a '95 s14? I bought one from someone who advertised it as a 95-96 greddy header. It is def a Greddy, but I have found no evidence that Greddy even made one for an s14. Their website doesn't mention it and I haven't seen a post mentioning one. How can i insure that it will work without taking the stock header/exhaust off?
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
I think they do. Maybe not, but I do recall seeing one somewhere. Post pics.
http://i-m-racing.com/gred9524head.html
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Yep, GReddy mad eone...they all crack eventually, like a stainless turbo manifold.
They are a decent design, but b/c they don't eliminate the primary cat like the Hotshot header...you won't see very big gains (couple RWHP increase, maybe).
- Brian
Timos240
Here is one of the pics of the greddy header. Orion, you mentioned they crack. How long can I expectit to hold together? In your opinion is it worth putting onif you already have it?
Ni2s4s0aSnX
I would say definately put it on. Anything is better than a stock header, and Greddy makes good products, it will definately make a difference.
:: orion ::
Yeah, I'd use it...but MAKE SURE you have the exhaust mounted to the trans (it comes form the factory like that...sometimes the mount won't fit 3" exhausts...FYI).
If the exhaust is secured and doesn't wiggle around all the time, it'll lessen the chance of cracking...even better, use a flex-joint, have it welded in.
- Brian
centralcoaster33
Car: 1997 Nissan 240SX #5
I want this header... Does anyone want to sell one? Not cracked obviously. If it cracked, perhaps you can use your warranty to get it replaced and then send me the replacement. I have $$ and am ready to buy. I've been searching for this part a long time...
centralcoaster33
New question to owners of the GReddy Street Legal header. Does this header have a logo, serial number, Executive Order Number, or any marking stamped, scratched, or welded onto it? If not, I believe it looks exactly like the Megan Racing 4-1 and T-Pros 4-1 header. My thought is to buy one of those and print the EO for GReddy and then tell the smog guy it's a GReddy so I can pass the visual...
