why did you put your name twice?240sx2nr95 wrote:Don't worry about the needle, it will be fine. If your going fast enough for that to be a problem a lot, then either you have a severe speeding issue, or your at the track enough to warrant buying a race-designed cluster such as that from STACK.
-Dan
-Dan
AIRFORCEONE wrote:yes i would like some more info. do you have the flu? what did you eat before you threw up? what color was it? did you throw up on the walls? did you have the toliet seat up? this is urgent info that i need to know.
I'm sorry Dan, but I really Lol'd there.AIRFORCEONE wrote:yes i would like some more info. do you have the flu? what did you eat before you threw up? what color was it? did you throw up on the walls? did you have the toliet seat up? this is urgent info that i need to know.
This type of behavior would not get you anything except a locked thread.AIRFORCEONE wrote:yes i would like some more info. do you have the flu? what did you eat before you threw up? what color was it? did you throw up on the walls? did you have the toliet seat up? this is urgent info that i need to know.
Both kouki and zenki speedos end at 120mph iirc, so might as well get a gauge from STACK, if you want to see your speed past 120mph...starkos14 wrote:besides, it would be nice to know how fast i was going.
The harnesses are different. I converted my 95 gauge harness to use kouki gauges.starkos14 wrote:I was thinking of getting a zenki gauge cluster for the purpose that i kept hitting trip button on my speedometer sat night. for those of you who dont know, theres more room between 120mph and the button on a zenki cluster. im just worried i might screw up the needle if the time comes where i really push the top end. the question i have is, i know the bolts will be the same on the cluster, but what about wiring and wire harnesses? im hoping for a plug and play install... anybody know if they are compatible? my cluster is a 97
