S14 Gauge cluster MPH problem
sr20detspec
my MPH gauge is not running accurate like when im driving around 30 its showing 60 do i need a new gauge cluster or something wrong with the speed sensor any info would be great [email protected]
extheflow
weird..if it's a compatability thing you could get an SGI from dakotadigital.com. thats how i got my S15 SS to read right on my S14 cluster.
sr20detspec
i didnt change the cluster its OEM so compatability is not a problem i think
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
go to a shop that adjusts speedometers.
-Dan
Nismo_Freak
Car: 89 Nissan 240SX
If all is stock sounds like you got an incorrect speed sensor... but you should be getting a fuel cut around 85 - 90 mph with it off that far.
If it's not fuel cutting on you then look into a new gauge cluster.
sr20detspec
yea i would get fuel cut so speed sensor is the problem?
Nismo_Freak
Yes.
sr20detspec
how can i get it fixed and how much thanks
Nismo_Freak
You could fix it yourself... not that difficult really. All you need is a good pair of plyers and some patience.
Obtain a new speed sensor from a junkyard car.
sr20detspec
where is the speed sensor located at? is it around clutch operating cylinder
Nismo_Freak
I'd suggest getting an FSM, the speed sensorplugs into the side of the gearbox. The highest sensor by the shifter is the neutral sensor. The one below it should be the speed sensor on your car. It's fairly large compared to the others.
