s14 gauge cluster into s13 wiring harness
s14danny
okay i was searching for a write up but could not find one. is this even possible? i have the s14 clips already.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
If your talking about wiring S14 gauge cluster into S13 than yes its possible. I'm not sure if it's going to fit or look right in S13 tho. Look up wiring for gauge S14 and S13 cluster on this web http://www.240edge.com/manuals/usdm-cars.html those are FSM's so their accurate.
Just get the S13 gauge harness its like 1.5' long goes between cluster and body harness, Remove the terminals from s13 gauge connector and try to repin into S14 gauge connector if those are the same size terminals. Otherwise you'll have to cut and solder wires.
You'll also need S14 Vehicle speed sensor, and maybe engine coolant temp sensor for gauge.
Good Luck.
