s14 fuel pump ?
driftfx1
Car: nissan s13, siltruck
the fuel pump is not coming on. it's a 95 with an notchback sr. walboro fuel pump. the car worked fine but now it died and the pump ain't comin out what should i look for.
virus77
Car: 95 S14, 71 240z, 97 e320
check the fuse first and then power the pump manualy with a extended wire from the battery and see if the pump comes on, if it doesnt the pump is dead. If it does come on then its your wiring somewhere.
da40
Car: 1995 SE 240sx
just check ur wiring ,this happened to be before with all the bumps and movement the ground wire some how got lose ,check the wires to the pump
driftfx1
virus77 wrote:check the fuse first and then power the pump manualy with a extended wire from the battery and see if the pump comes on, if it doesnt the pump is dead. If it does come on then its your wiring somewhere.
which wire is power I can't seem to find a wiring diagram.
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Had a similar problem a few days ago... first.. get a multi meter and check power at the fuel pump. My problem was that the wire that the pump is grounded with to the fuel tank was rotten... just regrounded and tadaa!!!
driftfx1
ok i got the pump to come on straight from the battery what now
ho1ywars
trace all the wires... rewire it if you have to..
