s14 fuel pump
98240
Where is the fuel pump located at?I looked in the trunk and I dont see anything. Anybody know
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
remove the rear seat and it will be sitting in a small dimple underneath.
daniel240
Car: cars/motocross
its in the tank.
jt15833
Car: 95' 240SX
its behind the back seat in the little oval between the trunk and the backseat, under the stock crossovers. you could probably get away going through the trunk, theres a metal plate on the passenger side with 4 10 mm bolts. inside theres 3 fuel lines and 2 connectors, disconnect all of em. get a fat flathead and a hammer and pound the black peice counter clockwise using the notches on the side. once off, take off the center peice and undo the 2 connecters under that and the one fuel line. reach against the back of the tank and the fuel pump is resting on a sliding peice, just pull up. theres a write up somewhere w/ pics but its easy
