s14 FSM question on harness
JCAP_Tuning
ok, this probably not the most intelligent question, but I need the answer:
Working on my main harness to plug into the F3 connector on the RB harness, I see the numbered locations of pins on the main harness, but where does it show in the FSM what each pin goes to on harness M63. Not the plug into the ECU, but the white connector that locks in together beside the ECU.
In the EC section I see the ECCS control harness wiring diagram and in the EL section I can see the harness layouts.
Am I just looking in the wrong place or what?
HotWIRED
The pin out for both the F3 and M63 is spread out through the whole FSM. Most of the time when you see a pin out for the F3 plug you'll see the M63 pin out also. The M63 is just a wiring juction block between the engine fuse box. You just need the pin out for KA F3 plug and mate them with the RB F3 plug and your good to go.
JCAP_Tuning
I can use the KA plug just have the wires spliced and rewired or repin right? I see they plug into one another fine, just hopefully I can use that one.
Does anyone have the pinouts for the RB and KA?
As soon as I get this all together I am going to write all this up for others.
