S14 Floor Problem
dabears_23
Car: 1998 Nissan 240sx LE
My S14 (98)..the floor has a hole, its not like the floor is cracked, there is a hole and theres nothing left to possibly weld this shut. The whole is right by the passenger side seat, right where it bolts up to the floor...therefore the passenger seat is lob sided and is leaned down. Thats the only visible hole, but also in the rear floor, on that same side, the carpet seems to have no support, like theres no metal under.
where can i buy the whole floor, atleast for the passenger side..i know that for old impalas they sell the floor pans, anything similar for a 240
please let me know asap
Dittoz7
Car: 1997 2f0WtY SE!
Custom Fabrication Time!
Or Cut One Out Of A S14 In The Junkyard And Swap It.
Edit: If It's Cause Of Rust, Remember To Sand That Sh*t Down And Spray Some Anti-Corrosion Stuff.
SirSilvia
Car: Sold both my babies
I had two spots under the driver and passenger side. and just used a couple squares of sheet metal and got them welded up, brazed them, primed top and bottom then undercoated the bottom. good as new
