s14 fal fans install to stock relays... HELP!!!
nismo_power
Car: 91 240sx fastback se
okay so i got a pair of fal fans and i got went to install it on my 95 s14...but only one fan will work? did i do something wrong?
i hooked both fans straight to the battery and they both work...so i know my fans are good!
i took out the old clutch fan and stock electric fan...i cut the plug for the stock e fan and wired my new fal fans into the stock wiring harness...
i looked up the stock wiring harness and correct me if im wrong here:
yellow= ground
black= ground
green= power
green= power
okay so i hooked fan one to yellow wire and blue wire and fan two to black wire and green wire...
now i know that the relay for fan Lo relay comes on at 203 degrees and fan high relay comes on at 212 degrees or when ac is on...
so after i hooked everything up and the car idle for a while only fan two will come on for like 10 sec then turn off or if i turn the ac on then it will come on and stay on...but fan one will not turn on?
so i unplugged the power for fan two then fan one will come on for a few sec then turn off and will come on and stay on if i turn the ac on?
okay so did i do it right or did i do it wrong?
im trying to have one fan come on at 203 degrees with the fan Lo relay and have the other fan come on at 212 degrees with fan High relay or when ac is on so both fan will be on at 212 degrees or when ac is on and only one fan will be on when 203 degrees...
is this possible?
are these temps to high or should i have the e fans kick in at a lower temp?
hope this makes sense to you guys...LOL
thanks guys in advance!
the two white wires with blue connectors are power from the fal fans and the two black wires with blue connectors are ground from the fal fans the wires with yellow connectors go to the stock wiring harness...
stock electric fan harness cut and wired into the fal fans?
