Im in need of the following wiring colors and posible locations for s14 black top. IM swaping a s14 black top into s13 just need to colors to wire it up.
FUEL PUMP RELAY TRNAS NEUTRAL SENSOR ECU RELAY ECU BACKUP POWER MAIN IGNITION POWER O2 SENSOR POWER ECU POWER IDLE AIR CONTROL VALVE POWER I need all these wire colors comming of the engine harness THANKS
