DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Jun 07, 2006 2:17 pm
yeah i wouldnt be surprised if you need a new tensioner, its that black thing under the front cover
mine was starting to make the nastiest noise of all time then i bought a new chain adn tensioner. I checked the new chain agaisnt my other three spare chains adn it had no noticable stretch compared to them. so, i wouldnt buythis if money is an object, otherwise from nissan its only like 30 bones
some people are refering to a black metal timing chain guide that bolts in right between the two cam sprockets, this thing was ordered to be removed from nissan. on three of my four KA, these have been broken off before i got the motors, so its very very common.
so remove that if its there. if its not, you can tell that the tensioner is crap because the chain physically hits the valve cover. you can either put your ear on the valvecover very near the front, or you can use a screwdriver or ratchet to amplify the noise (and you wont get cut by your fan). if you have the valve cover off you can see the chains damage to the valve cover
