S14 ENGINE S13 5SPEED TRANS
92coupe-special
Need help!!!I blew my motor recently in my 92 240 :(
I was however able to get a complete s14 motor..only problem is I wasn't able to get the ecu and wiring harness..so wat I did was grab the intake nexhaust manifolds n swapped it on the s14 motor everything lined up perfect..but wat I'm curious to kno is will the flywheel need to b from a s14 or can i use the s13 flywheel?
N if I do need a s14 flywheel will it still b sprite with the s13 trans?
Any n all help if anyone knows will b greatly appreciated..I need to get my baby running again lol
kylethestyle
Car: 1995 Nissan 240SX
You should be good. Just remember to use the S13 distributor and MAF sensor. Use your s13 flywheel, no need for an S14 one. If your S13 cams are still good, swap them over into the S14 engine for a slight boost in power. Just play around with it. That's the best way to learn. :)
92coupe-special
Thanx that jus saved me sum money..all that was done I jus asked about the flywheel bcuz when I first did all that the motor would crank n turn over but now it jus sounds like the starters not making good contact with the flywheel so either way everything needs to come back out again
