Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Tue Dec 26, 2006 11:17 am
you are in for a little more than a quick rewire if you want the electronic climate control to work. you also need a sunlight sensor, a air temp sensor, and i believe the heater flap control motor (or air temp control motor, whatever people call it). there is some custom fitting to do along with rewiring. Do a search for it, i believe someone got it to work on their s13, so it should be ...similar for an s14
