Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Mon Sep 13, 2004 4:51 am
How did you test your alarm? Does the light blink? One way you can try is leave the windows open, lock your doors then close the doors, wait a few minutes for the alarm to arm and then reach your hands inside and unlock the door, the alarm then should go off, if not, most likely a fuse or maybe it just crapped out. For remote entry the remote probably was press too many times out of range, when this happens the code on the remote and the code in the car is different. It could also be the battery in the remote. As for your radio, it would be nice if you have a multimeter but if not, it sounds like the constant on power is probably dead, what you wanna do is find a constant either from your ignition or directly from the battery and hook it up to the yellow wire on the deck and try turning it on again. I hope this helps a little.
