Salem240 »
https://forums.nicoclub.com/salem240-u105033.html
Fri Sep 18, 2009 1:45 am
I ended up using universal vac caps to plug up the vac lines. And when I removed the canister I totally removed the hard line that comes from the bottom of the can, and removed the hard line from the engine bay that goes from the gas tank to the top of the can. I looped the end of the hard line at the engine bay on the one that runs from the gas tank to the bay, so no water can get in. Everything seems to work fine but I'm still getting 2 codes cause the egr isn't there. The Tech thread sucks lately.... it's slow and not much help being posted up. I try to help when I can, even if it sounds like a simple problem to me, some times people have a brain fart and a simple question needs a simple answer
