S14 Ecu
JOZy
Car: S13 Coupe
Anyone know if i can use an OBDI s14 ecu on my 96 OBDII s14?
JOZy
Car: S13 Coupe
bump ... anyone??
Xj220gt
Car: 1995 Nissan 240sx SE
Auto ECU swap myths and faq's:
This throws the check engine light. SMOG PEOPLE BE AWARE!
1. The car will run the same2. 95 ecu will work in any s143. 96-up will only work in 96-up4. Removes speed governor5. Higher rev limiter (7200rpm)
The effects1. Cold start, it idles at 1500 then drops to 700 like normal after a few minutes2. The idle raises when you have the clutch in and move the shifter3. Throws trans code4. 95 ecu in 96-up throws o2 sensor code(although it still runs fine)5. Slightly better fuel economy
found on this write up: http://www.nicoclub.com/articles.php?id=363519
JOZy
Car: S13 Coupe
its a 5speed ecu from a 95, i just need to know if it will work normal? because its the only ecu i found, obd1 from a 95, and mine is a 96 obd2, im pretty sure my ecu is bad but i dont want to buy the obd1 ecu if it wont work. thanks for ur input but if anyone couls help with my more direct question
Xj220gt
From what I have read, It will work fine except for it throwing an 02 sensor code. but the car should run fine.
ThuG LyFe
Car: 95 S14
i have a auto ecu from a 95...anyone interested?
[email protected]
JOZy
Car: S13 Coupe
thanks
