Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Sun Apr 25, 2004 7:33 am
Here's what I found out from doing a VLSD /w abs into a 240 that has no abs and no vlsd. Driveshafts may be slightly if at all different, (put them both end to end and no difference is detectable). The VLSD /w abs is longer but from what it looks like the non abs shaft does not seat all the way into the transmission as though it's not suppose to, that's where the dust cover comes in. With the VLSD /w abs, the shaft just goes into the transmission a little bit more.
If some of your are questioning if all the parts are original. Here's where i got all the parts from, My friend has a S13 with Hicas, abs, and Vlsd while his new car, another S13 has neither hicas, abs, nor vlsd. We compared the two driveshafts and no difference was detectable. looking at the end where the shaft goes into the transmission, you can see the oil marks left behind by the oil seal rings that the shaft does not go all the way into the transmission where as the mark on the s13's driveshaft w/ lsd has a .5" difference in the markings on the shaft. That's what I found out after doing the swap. Perhaps this will answer a few questions.
I'm sure this is the exact same thing with S14's.
