s14 Drivers power window replacement
cstang1968
Well my driver's side power window went out over 6 months ago and i got a replacement motor from structure240sx over 2 months ago and i finally got around to replacing the motor last week. I searched around nico for a long time for detailed info and came up empty, and i also searched my FSM and came up empty. So i decided to tear into it and here's how it went:
Preliminary note:I used the FSM to leak down test the electrical system to figure out is was in fact the motor that needs replacing. BF-23 is the page in the FSM where the test is located and you will need a DMM.
door panel removal:First remove the 3 screws at the bottom of the door panel, the 1 screw holding the entire power window switch assembly so the door panel there may be a plasic cover over the screw (in my case it was a penny wrapped in electrical tape hurray for the cheap old owner), the 1 screw holding the plastic cover over the inside door handle and remove the plastic cover. Next unhook the plug that is connected to the window switch panel and slide the wires into the door as to not get caught when you pull the panel off. Now pull at the bottom of the panel away from the door, there will be 2-3 plastic plugs that will pop out. Finally lift the panel vertically off the door.
Getting to the motor:I found it easier to get to the nut holding the window glass to the track assembly as well as getting a hand on the whole assembly by removing the speaker assembly which is held on by 4 screws. I also removed the arm rest support (u shaped stamped steel) that is held by 2 10mm bolts. Now my window was stuck in the up position so i removed the 4 zinc plated (gold colored) 10 mm bolts holding the track assembly to the stamped steel door ( this will allow the window to go down to gain access to the 2 nuts holding the window to the glass) as well as the 2 10 mm nuts that hold the slide mechanism (the nut on the right is adjustable so mark where is was screwed in so that your window is aligned the same as before or adjust as needed on reinstallation). Also, it would be a good idea to get help from someone to hold the window up and move it up and down as needbe, i found the little brother to be the perfect tool. Next I removed the 2 10 mm nut that holds the glass to the tracks. Now the one on the right proved to be difficult and i had to have my bro hold the top of the glass very low (about 3" up from the bottom of the sill) so that i could get the nut through one of the circular access holes in the stamped steel door panel. Next fold up the tracks and remove them, then slowly lower the glass down and let it rest in the door cavity.
Old motor removal and new installation:The motor is only held by 3 machine phillips head screws. Now this is very important. The motor is tensioned by a wound spring so when you remove the old motor the track teeth will move a few teeth. The first attempt i made I didn't pay any attention to this and found out that i could not get the 4 10mm bolts back into place. So when you go to screw the new motor in place push the bar with the teeth up so that the gear on the motor is engaging somewhere in the middle of the teeth on the track. Scew in all 3 machine screws tightly and reinstall. I regreased the tracks while they were out so now my window goes up very smoothly. Now reinstall everything hooking the window glass to the tracks first. (you will need a helper again to hold the window)
Now this whole operation took me a little over 45 mins even after having to remove the thing a second time and readjust the teeth.
Modified by cstang1968 at 9:51 PM 1/2/2005
Rockenreno
Car: 1997 BMW M3
cool, good write up
s14superman
Car: 97 s14
thank you for the info!
n00b240
Car: '03 6MT
After searching like a ***** in the forums, I finally found this thread. I got my window motor, but had no clue how to take the old one out. I did it by myself, I should have called someone tho, it woulda made life much easier. I put it back in in about 30 mins tho.
This SHOULD either be a sticky or in a FAQ, or in the articles section for installs. This thread was hard to find
