S14 Drag Tires
240SXer
Car: 1995 240sx SE (2jz powered)
Okay, I purchased some 15x8 rims and some 275/50/R15 tires. Needless to say they didnt fit, they were too tell, they rubbed the fender. The tires were 130 each, and the rims were 50 each. So that's $360 down the drain. Well, i'm gonna sell the tires for 200 so i'll make up some. Anyway, the rims by themselves stick out pretty far (as you can see from the pix). I'm curious what tires I may be able to fit on these rims still. The ones in the pix are the 275/50/15s.
I think I can get GForce T/A drag Radials 225/50/15 to fit on my 15x8 rims.
Or I can get different rims as long as they're cheap. Or if there is any other tire that is wide and grippy but not tall that will work too.
These are ONLY for drag. They're not going to be driven on the street much. I don't care how they look, I just need them to hook.
What kinda drag tires do other people have on their S14s?
http://www.racingonthestreet.c...icks/
Nismo_Freak
Car: 89 Nissan 240SX
Why not try a set of ET Streets?
If they are drag specific why skimp?
26x10.50 ET Street = Bling
240SXer
I have no clue how to do the conversion. Will those ET Streets fit on my 15in rim? They'd have to be not very tall.. I can't do that standard to metric conversion to a degree that i'm confident the tire will fit.
Nismo_Freak
26x10.5 = 26" tall x 10.5" section width
And yes they will fit on your 15" rims.
240SXer
The overall diameter on my Comp TA tires is 26.1, so 26 is still too big. I'd need a 25 or so to be the best
Aries
Car: LT1 240SS
the 26 inch ET street will fit.remember that you are going to be using only about 70% of the tire, not the full height.
The tires on my car in the sig are 27x10.5x15 ET streets.the 8 inch wide wheel is probably where you are having your problem. try using a 26x10.5x15 or 26x9x15 on a STOCK rim.you'll see it clear the spring and inner fender walls, and still have plenty of traction.
PS: ET Streets are street legal ;)
240SXer
What would be the specs on a stock rim? 15x7? What about the backspacing and stuff? I can buy one but I'll need to know the specs so I know exactly what to get.
240SXer
What kinda 60fts do you get with the 240SS. Best I've gotten was a 2.15 with a high 13 1/4 mile. That's with my Kumo 712s, 225
Structure240sx
i've been searching around for drag radial too. im looking for sumthin to put on my stock se wheels since they are jsut sittin around. i found bf goodrich t/a that will fit. might be an option for u since ur using stock wheels, maybe jsut go pick up two more for the drag radials
but im also thinkin about maybe gettin nitto 555r's on my 17's any idea guys.
240SXer
None of the bf goodrich Drag tires (they make two) will fit on any 16in rim (per their site)..... Do you know of one that will?
Structure240sx
240SXer
Are you sure they still make that size? They don't show it on their website.
Anyone know if a 255/50 will fit on a stock S14 rim and tuck in the fender without rubbing?
Structure240sx
im jsut going off of what jegs website says
i did some rough calculations and it seems that it will fit. should be as tall as my current wheel/tire set up
240SXer
255 seems like it may rub on the inside.. Maybe even stick out and rub the fender.. When are you getting them?
Structure240sx
not really sure prolly not for like a month or so, once the snow is gone and the track is open regularly
240SXer
My friend has some 315s on his transAM, those tires aren't very streetable. I've gotta see if I can find some stock S14 rims (2 of them).
Structure240sx
shouldnt be too hard to fine them. i would sell u my other 2 but i rather run all 4 so people wont get any ideas of drag tires, maybe
240SXer
Aries, if you're still around. Would your tires rub if they were out further than your fender? Like if they stuck out like mine do.
