benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Wed May 11, 2005 9:57 am
I have always despised it when folks would come along and refuse to answer your question, but rather tell you that it isn't possible and you should take it to a shop. Well damnit... they're right. There's just no way around it. It is possible that you can improve it without an alignment computer, but not likely. Would I try it? Yes, but I'm a stubborn mother****** and am also very familiar with how it goes with an alignment computer. You'd probably be taking a shot in the dark if you've never done an alignment at all. If you simply must take a stab at it, find an FSM for the info on how to do it, then work very slowly. Turn the tierods only one turn at a time and test drive in between. You will virtually never get it good enough for an alignment computer to say that it's ok, but you might be able to get rid of the pull you're experiencing. I would only mess with toe, and only on the front. Any other adjustments are not only virtually impossible to eyeball, but also probably aren't causing any trouble.
The first thing I should have said is this - make sure all your tires are properly inflated. A low tire can easily cause a pull to one direction or the other. If that's not it, do your best to find a friend who either works in a shop or has access to an alignment computer at school or something. I couldn't bring myself to pay for an alignment either...
